Hi all,
I’ve a license with 50 source channels / 100 webrtc output, and I provide to users WebRTC and WebSocket streaming based on user agent (iOS WebRTC, all other WebSocket). Installed on Ubuntu 18.04 server, h5s version r9.8.0923.19, build time 2019/09/21 18:15:29.
Yesterday server stops to erogate WS streaming (in that moment about 10 concurrent plays), but from an iOS device I was able to receive streaming.
This are the only log traces I’ve dumped from syslog registry near the issue (16:16 it’s my restart of service):
Apr 28 16:09:37 multistream-str h5ss[11959]: Run video gap -16674110772625
Apr 28 16:09:37 multistream-str h5ss[11959]: Run Got a End Frame
Apr 28 16:16:11 multistream-str systemd[1]: Stopping h5ss - html5 streaming server…
Apr 28 16:16:11 multistream-str systemd[1]: h5ss.service: Main process exited, code=killed, status=9/KILL
Apr 28 16:16:12 multistream-str systemd[1]: h5ss.service: Failed with result ‘signal’.
Apr 28 16:16:12 multistream-str systemd[1]: Stopped h5ss - html5 streaming server.
Apr 28 16:16:12 multistream-str systemd[1]: Starting h5ss - html5 streaming server…
Apr 28 16:16:12 multistream-str systemd[1]: Started h5ss - html5 streaming server.
Apr 28 16:16:33 multistream-str h5ss[885]: Application dir --> /opt/h5ss/
In h5s log only API usage in corresponding time:
[2020-04-28 16:09:34.118] [h5ss] [info] [t12322] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/h5srtcapi
[2020-04-28 16:09:34.255] [h5ss] [info] [t12320] authorize successfully dcf023b7-360d-43f6-974e-5a147251d7ab /api/v1/Keepalive
[2020-04-28 16:09:37.656] [h5ss] [info] [t12324] authorize successfully c97ad774-de05-4863-8c4f-d58394d025a3 /api/v1/GetImage
[2020-04-28 16:09:37.657] [h5ss] [info] [t12325] authorize successfully c97ad774-de05-4863-8c4f-d58394d025a3 /api/v1/GetImage
[2020-04-28 16:09:37.660] [h5ss] [info] [t12320] authorize successfully c97ad774-de05-4863-8c4f-d58394d025a3 /api/v1/Keepalive
[2020-04-28 16:09:37.683] [h5ss] [info] [t12323] authorize successfully c97ad774-de05-4863-8c4f-d58394d025a3 /api/v1/GetImage
[2020-04-28 16:09:37.714] [h5ss] [info] [t12326] authorize successfully c97ad774-de05-4863-8c4f-d58394d025a3 /api/v1/GetImage
[2020-04-28 16:09:37.731] [h5ss] [info] [t12327] authorize successfully c97ad774-de05-4863-8c4f-d58394d025a3 /api/v1/GetImage
[2020-04-28 16:09:37.915] [h5ss] [info] [t12320] authorize successfully 7a99f1a7-ffb0-4ffa-b3c1-4c4634a7fdef /api/v1/Keepalive
[2020-04-28 16:09:38.923] [h5ss] [info] [t12320] authorize successfully 55f015a9-96ee-4d9e-9a23-4d18d81060d0 /api/v1/Keepalive
[2020-04-28 16:09:40.700] [h5ss] [info] [t12320] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/GetImage
[2020-04-28 16:09:40.955] [h5ss] [info] [t12324] authorize successfully 1aecb1f7-51b3-401c-8286-bd7548170abd /api/v1/h5swsapi
[2020-04-28 16:09:41.009] [h5ss] [info] [t12323] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/GetImage
[2020-04-28 16:09:41.010] [h5ss] [info] [t12320] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/GetImage
[2020-04-28 16:09:41.011] [h5ss] [info] [t12322] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/GetImage
[2020-04-28 16:09:41.309] [h5ss] [info] [t12325] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/GetImage
[2020-04-28 16:09:41.479] [h5ss] [info] [t12320] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/GetImage
[2020-04-28 16:09:41.621] [h5ss] [info] [t12322] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/GetImage
[2020-04-28 16:09:41.625] [h5ss] [info] [t12323] authorize successfully 31c024be-227e-467c-a2b5-a735e976f173 /api/v1/GetImage
[2020-04-28 16:09:41.798] [h5ss] [info] [t12322] authorize successfully 1aecb1f7-51b3-401c-8286-bd7548170abd /api/v1/GetRunInfo
[2020-04-28 16:09:41.859] [h5ss] [info] [t12323] authorize successfully 1aecb1f7-51b3-401c-8286-bd7548170abd /api/v1/Keepalive
[2020-04-28 16:09:41.876] [h5ss] [info] [t12325] authorize successfully 1aecb1f7-51b3-401c-8286-bd7548170abd /api/v1/h5srtcapi/Status
This is issue happened already about 7 days ago.
Could you give me support please?
Thanks
Sebastian
