6.3 0831 2018
1.Fix windows released package don’t have openssl gencertificate tool.
2.Fix Dahua STREAM-ASSIST-FRAME RTP payload format unknown or not supported crash issue
(H5s-r6.2 启动h5ss.exe就闪退)
3.Disable 10090 debug port.
4.Fix resolution change ws video sawtooth issue.
5.Fix only one device can’t show in the h5console live device tree.
6.Disable HLS by default.
7.Fix cloud src can be restful api delete issue.
8.Fix linux systemd can’t auto restart issue.
9.Add don’t use RTP TS option in config.
10.Add rotating log mode.
11.Add snapshot and record botton in the liveview.
